-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   Fender question (http://forums.pelicanparts.com/showthread.php?t=849805)
brianvb 02-02-2015 08:53 AM
Fender question
I bought a 91 targa shell . Will the fender lips match if I put them on a 68 widebody T that I want to turn back to stock ?
Thanks, you guys are a great resource . I have cars - I need knowledge. Thanks again . Brian vb
CountD 02-02-2015 09:41 AM
A 964 shell to use the fenders on a '68? No, it won't match. Wait for some stock fenders if they ever come up. Even impact car front fenders vary quite a bit through the years though they all are supposed to 'fit'.
pors1968 02-02-2015 03:31 PM
You have to use 65-68 front fender they have no flair .Briand you have 1968 S soofwindow macthing number that +100k car buy two new quater and front fender.
ficke 02-02-2015 04:39 PM
Please take this good advice!
Find used /new fenders for a SWB 911 and not re-bastardize the car, otherwise you are only making a sideways change and not an improvement to show for your work and money outlay.
brianvb 02-02-2015 10:16 PM
Ok Thanks. I have a 68t dressed up to look like an 89 turbo = yuk ! I want it to go back.
Re: My 68s widebody, I signed a contract promising the guy that sold it to me to never cut the fenders off. To bad for me.
brianvb 02-02-2015 10:25 PM
Surprisingly, I also need front fenders for my 79 930 which is slanted, and shouldn't be.
ficke 02-03-2015 04:38 AM
Well, you have front fenders for your 930 already on your 68T with the 89 turbo look, that is a good start for undoing the crazy ideas of the time.
Sounds like you have some fun cars:)
brianvb 02-03-2015 08:23 AM
Neat suggestion. My 79 930 is wicked and the 68t is a POS. I'll check but I'm sure the 68t will have copious bondo. I need my 79 930 to be perfect so I'll try to find perfect fenders. Does the 79 factory front fenders have welding ? Or are the built "flared" ?
As usual, thank you for all helpful comments.
techweenie 02-03-2015 08:57 AM
There is little real "flare" difference between SWB and LWB. It's just the outer lip that sticks out maybe 10mm more in the later cars.
Very important to note: if you are doing a high quality 'rightdate' on your 68, be aware the 68 front fenders are one year only configuration.
If you look at the wheel well openings from underneath, the inner edge of the lip is trimmed away toward the center on a 68 fender. The flange is of consistent thickness on 65-67 fenders that otherwise appear the same.
Also, if you haven't shopped for early fenders before, all SWB fenders have "boxed" areas for the turn signal assembly and all LWB fenders have open areas.
ficke 02-03-2015 10:07 AM
They were welded on flares for sure in 1979 from the factory.
