-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   1969 911s engine transmission combo (http://forums.pelicanparts.com/showthread.php?t=853870)
goldsc78258 02-28-2015 04:40 AM
I'm trying to figure out the value of an engine transmission combo from a 1969 911s.
Engine was running when taken out on webbers it now has the correct MFI with rebuild pump
transmission shifted perfectly I think I still have videos of both if I can find them
Any help on this would be appreciated
techweenie 02-28-2015 06:54 AM
Nothing less than $18K, and possibly quite a bit more, depending on details. Having not run with this MFI installed, someone is looking at a fair amount of expense setting it up, checking and adjusting, and if the throttle bodies need rebuilding, more $$$ still. What is the condition of the clutch? It's a rare setup for the 69S. How long has it been sitting without running?
goldsc78258 03-01-2015 03:33 PM
Anybody else would like to chime in?
ficke 03-01-2015 04:57 PM
It is really hard to put a price on a moving target like parts for early 911S cars. I think Techweenie did about as well as anybody can.
MFIS system is at least 6k even if it needs to be rebuilt. a 69S long block core would have to be worth 10K and a trans. is worth at least 2k, so there you have it, Techweenies 18K estimate is a good low side guess.
You never know until you advertise and people put their money up.
copbait73 03-01-2015 05:32 PM
Go to Early S site and see if you can match it to a chassis. Worth a lot more then.
