Parts identification and value???
Does anyone know what model year an 11 blade fan/ alternator
#9011061010R Tried cross referencing and came up empty.
1967-1968 245 MM, die cast magnesium with no provision for coil studs. There was also a sand cast mag version with the same number but yours is the die cast version. The sand cast and the die cast were identical in every dimension other than the amperage of the alternator installed, 35 for sand cast, and 55 for die cast
Thank you Gearby
