-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   1973 914 2.0L Valuation (originally delphi green metallic) (http://forums.pelicanparts.com/showthread.php?t=873868)
Dynamik 07-08-2015 08:15 AM
I am selling my father’s 1973 914 2.0L. I am looking for a range of valuations understanding it is difficult to estimate without a thorough inspection. I will list vehicle details and then some pros and cons. This is a tough crowd but I am open to opinions.
General Details:
-Car was originally Delphi Green Metallic (verified via L 99A paint code and some areas of the car exposing original paint), now painted red (perhaps guards red?).
-Black Interior
-Unknown mileage
-Weber carburetors (original fuel injection system is gone)
-F/R factory sway bars
-Aftermarket Dino steering wheel
-Aftermarket stereo
-Aftermarket front rubber lip
-Aftermarket driver side rear view mirror
-Aftermarket rocker panel covers
-Aftermarket exhaust (monza?)
-Aftermarket rear spoiler
-All chrome was painted black (can be stripped)
-150mph speedo
Pros:
-Originally Delphi green metallic
-No rust in h&!! hole (believe this was repaired years ago but would need to review records)
-Believed to be original floor pans (did not note any rust after a cursory look)
-Rockers appear solid (did not note any rust after a cursory look)
-Rear trunk appears flawless
-Seats are being recovered to factory spec
Cons:
-Car has sat for at least 4 years (was running well when parked)
-Evidence of mice but believe they have been eradicated (needs a good cleaning to eliminate remnants)
-Some rust behind headlights
-No COA to verify #s matching, but am not aware of any swaps
-Some rust in the passenger door seams
-Surface rust on battery tray (no holes or bubbles)
I am looking for a range of valuations for the car as is. I believe this car will start and run with the proper steps taken to fire it up after sitting 4+ years. In fact I may get the car running as it will probably make a difference in sale.
The car comes with lots of spares (top, interior bits, trim, etc...).
Thank you in advance.
Photos are unedited cell phone pics...
http://forums.pelicanparts.com/uploa...1436368100.jpg
http://forums.pelicanparts.com/uploa...1436368137.jpg
http://forums.pelicanparts.com/uploa...1436368159.jpg
http://forums.pelicanparts.com/uploa...1436368215.jpg
http://forums.pelicanparts.com/uploa...1436368250.jpg
http://forums.pelicanparts.com/uploa...1436368281.jpg
http://forums.pelicanparts.com/uploa...1436368327.jpg
http://forums.pelicanparts.com/uploa...1436368359.jpg
http://forums.pelicanparts.com/uploa...1436368401.jpg
http://forums.pelicanparts.com/uploa...1436368501.jpg
biosurfer1 07-08-2015 09:12 AM
I'd say $5-7k, possibly.
The color code doesn't really mean much unless you're going for a ground up restoration, and if thats the case, then all the aftermarket stuff is a real con since it will all have to be replaced. Factor in that plus the costs of restoration and I'd say you're looking at $5-7k if you can get it running and someone wants it in it's current state.
914's are increasing in value but no one is going to spend $5k on a car, dump $15k+ into a restoration to have a car worth $15-20k after the fact
