carrerarsr65
whats it worth$$??
1979 911 3.0 fresh rebuild 3.0 motor big port heads just done by cgarr,twin plugged,964 cams,j e 10.5 to 1 pistons,rods rebuilt by ollies,new timing chains,weber 40idas,itg filters, headers,with 2in 2out modded danssk,hpv-1crank fire ignition,all new bearings,seals,and gaskets,just did my 500 valve adjust doesn't leak a drop
What's the rest of the car like?
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Banned but not out, yet..
+1
An air cooled refrigerator. ‘Mein Teil’ |
Hey guys I have a similar question. What do you think the worth of a '68 912 that has a low miles '71 911T motor trans in it? It does have a turbo 911 wide body kit on it (not steel :d) And body has about 103k. Everything works as it should. Runs and drives well, leaks tiny bit of oil. New clutch. There is some stress cracks in the wide body kit and it seems like it was done a while ago with a paint job needed soon. Only bad rust is the driver side floor pan, few holes in it. Updated interior but does need some odds and ends finished up. What do you think?
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Just selling the motor OP?
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
carrerarsr65
hey
the car is a 6 out 10 typical rust in rockers/kidneys overall though the shell is solid its a row car no s/roof crank windows no n light
Troll Hunter
Not enough info or pix of the 79SC to price.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
gearhead
$15-30k based on the information provided.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
carrerarsr65
thanks matt .forgot to mention wevo eng/trans mount,wevo psj,shift bushing kit,sparco seat,momo wheel,ER spring plate bushings,countless hours cleaning!!
Troll Hunter
Throw me a PM when you come up with a price.
Nick
carrerarsr65
Bump
gearhead
You have given no new details, so neither have we.
If you want to know what your car is worth, basically write your FS ad. Without the kind of detail one would find in an ad, we just have a range for you. Your car is worth between $15k and...
