Are these real 993 Cup Wheels???
Hi all,
Not sure if the right place to post this question but I just bought a set of wheels off of CL for my 95 993 C2, the ad described them as: "Genuine OEM Porsche 993 Carrera Cup II Wheels Factory Rims Set in very nice condition with almost new tires. 205/50r17 255/40r17" Now I'm doubtful they are OEM as I don't see the Porsche parts number on them. Can anyone ID these wheels? Thanks in advance for the help! ![]() ![]() ![]() ![]() ![]()
1970 911T Conda Green, 1966 912 2005 955 Manual Transmission Overland Build 1971 Alfa Romeo 1750 Spider 1984 Mercedes-Benz Euro 240d Manual Transmission 2000 BMW E39 528iT wagon manual trani going on BAT soon. Last edited by porschophile; 02-20-2016 at 11:26 AM.. |
Nope. U should have the offset and width of wheel stamped beside the valve.
Here is how it should look like
http://rennlist.com/forums/attachments/964-forum/386540d1253241060-fs-17-cup-wheels-oem-porsche-993-wheels-wheel3.jpg Think they are Mille Miglias, give them back to seller if you can.
'76 930 |
and if u are going to keep these reps, check the offsets - make sure they are correct for a 993
Thanks much for the info!
Good news is, thanks to pelican, the seller is taking them back...well meaning guy, seems like an honest mistake.
Yes reliable seller. Good for you too. You know you have Miglias when you hit a mild pothole or a drain hole cover at 30 mph.
You notice a small rhytmic thumping sound afterwards, as if you have a flat spot on tire. Did I lock my brakes? No it is your Miglias, they are no longer round.. One-time-Miglia owner
'76 930 |
I believe the dead-giveaway here would be 'Made In Italy'? Am I correct?
