1978 Porsche 911SC value?
Hi Everyone,
What is the current value on a good running 911SC ? good driving condition not a garage queen or concourse quality Thanks J. ![]()
I'll jump in with 35k
25-35k
Troll Hunter
Lack of detail means lack of accuracy. Christian has it about right, but all sorts of factors could raise or lower his numbers.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Hello
Your answer probably depends on a lot of things - Is it matching numbers car? Has the engine been rebuilt recently? If so to what extent? Engine compression numbers would be good to know - they can give confidence to the buyer. Is there obvious rust? What's the condition of the interior? Do you have maintenance records? I would think that $25-$35k is a pretty good range. Your car looks nice in the pictures. Look around to see what other cars like these are selling. Compare that to your car. Set a bottom line in your mind before you advertise. Good luck. Sent from my iPhone using Tapatalk |
Thanks everyone for all the comments !
Why so many updates on the car? Carrera fog enclosures...... high brake light..... was this a re-paint?
