Plavan's Avatar
Price Check: Virgin 1966 Aluminum 2.0L case
Just checking the price on a 1966 911 virgin aluminum 2.0L case.
And a ton of early S (red) and other engine fan shrouds
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 04-04-2018, 07:51 AM
7-10K on the case.
shrouds are not worth much as there are good reproductions that look better than used shrouds. $250 is all the money for a good used shroud.
Old 04-04-2018, 04:58 PM
SalParadise's Avatar
Nice case. I wish they stayed with aluminum from this time on. But they did not.
Old 04-04-2018, 06:24 PM
gearhead
Ping catorce. I think he might be looking for a small displacement sample for his casting project.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-04-2018, 10:36 PM
virgin
Does virgin case mean it has never has had a shaft inserted?Ciao
Old 04-05-2018, 04:16 AM
Plavan's Avatar
Meaning it was torn down from original factory build and never modified in any way.
Chad Plavan
Old 04-05-2018, 09:13 AM
I think you missed the joke.
Old 04-05-2018, 09:14 AM
Plavan's Avatar
You are right.... LOLOLOLOLOLOL
Chad Plavan
Old 04-05-2018, 09:15 AM
touringmandan's Avatar
A Virgin like Madonna?- she's had plenty of shafts and rods in her "case".
Old 04-06-2018, 12:11 PM
G60SuperCharger's Avatar
LOL you guys are too funny.
Does the case have a serial number stamped into it or is it blank? If numbered it would be worth a lot to the current owner of the original car that got a replacement case.
I would post the engine serial number on the early S registry. There's a thread there called Engines Lost and Found where you can post it. Several cars and engines have been reunited this way.
Old 04-09-2018, 09:33 AM
Plavan's Avatar
Chad Plavan
Old 04-09-2018, 09:50 AM
Plavan's Avatar
Just realized my race motor is built on S/N 901068!
Chad Plavan
Old 04-09-2018, 02:20 PM
What is the surprise?
Old 04-09-2018, 02:41 PM
Plavan's Avatar
Its a 1965 case.
Chad Plavan
Old 04-09-2018, 02:42 PM
Its a 1965 case.
Very common to use back in the day, sand cast cases for race engines, stronger and cheaper than the later mag cases for the longest time.
So if your engine race engine was put together more than 10 years ago it was very common to use the sand cast cases.
I bought an old race car and it had a early 64 case used for racing in the IMSA series.
I sold the case last year for 5k, and it was not a virgin. Line bored, fins knocked off and the spigots were enlarged.
I think the 65 cases are worth more than the 64 case because there are more 65 cars than 64 cars. It was hard to find someone who wanted the 64 case I had.
Old 04-09-2018, 02:52 PM
