Science is NOT optional
996, How long can it sit before it needs a charge
In other words, what can you expect if you leave the car for 3 days, a week, longer? I don't want to have to hook up the trickle charger if I don't need to.
PCA member since 1993 |
You will need to. Unless its your daily driver it'll need a trickle charger. I've heard people have trouble starting 3days after sitting on the short side and definitely by a week of sitting you'll have issues.
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100 |
Mine sits for weeks at a time.
I don’t drive it more than a day or two some weeks, and depending on my schedule and weather, it can be a while. I do put a maintainer on it pretty soon now because of the snow and salt. |
Second post above. my car sits for 2-3 weeks at a time. Starts right up every time. I do have a 2yr old heavy duty battery
better than 2 days anyway. it would be nice if you could put them to hibernate...
Is it worse with the car locked or unlocked?
It's very important removing the key , and locking the car.
Like this , all the electronic system is desactivated .
LIGHTER = FASTER !!! |
Uncertifiable!!!
I don’t find any measurable difference in battery discharge whether the car is locked or unlocked. As others have noted, you can’t leave the key in. Ask me how I know.
Johan
Well my battery is dead. Mg car was left unlocked & didnt start it for 2 weeks. Was on vacation. Need a new battery?
Sent from my SM-N960U using Tapatalk |
Can you jump it ? I think the manual says no but maybe that's over reacting.
Won't jump. Tried charging battery too. Won't hold a charge.
as for measurable difference, did you attempt to really compare?
You can jump it, but safer to use charger. If it is totally flat (i.e. no current available) a standard charger won't work - in that case you can connect another battery to the flat one and then the charger will kick in, then you can disconnect the good battery. But if it won't hold a charge you need a new battery. Allowing a lead acid battery to fully discharge it kills it. The pain is if the frunk is closed and you have a dead battery.... RTFM. Cheers |
I learn the hard way, all locked up and the battery dead. lol I always un latch the front when I pull it in the garage. Lot easier when you find out its dead. Going get a new battery tender brand maintainer, see if that works. This car eats batteries. But I wasn't locking the doors, will try that now. with the maintainer.
The hood is unlatched? The door is unlocked? A window is down?
Just want to add that my 99 C2 used to drive me completely mad.
I replaced the battery with a similar one when I bought the car. The battery wouldn't last longer than a week, even when the car was left locked. Eventually figured out that the PO had put too small a battery in. When I replaced the battery again, I used the proper capacity and the issue went away. Can leave the car for weeks now (provided it is locked, leaving open does drain it faster!) Maybe worth checking. |
The car has a stand by mode that stops after 5 days to save battery...
Apparently you can bump start them. It's mentioned in the operating manual.
