Coolant bleed valve
When engine is up to temperature, the bleed valve is open, is this normal
yes, it is actually a vacuum break.
As the engine cools with the bail holding it up the tank can go to atmospheric pressure. That encourages trapped air to migrate to the tank and then out. With no bail engagement the shaft just rides up and down depending on pressure/vacuum in the tank.
