996 Turbo noise
Getting this really bad vibration like a loud buzzing going through the car at around 3800 to 4400 revs in all gears. You can feel it in clutch pedal.
Had new clutch, flywheel perfect, new muffler, turbos are good, checked for loose engine mounts, etc. Ideas? |
worn trans mount? Replace the engine mounts, they don't get loose they sag. Same with the trans mount. ----------------------------------------------------------------------------------------
Book #: 10 2539 005 Description: Driveshaft Flex Disc Applications: Carrera 4 99 thru 05 Manufacturer: O.E.M. __________________
