Check engine light on 99 Carrera
Hey guys,
I have a 99 carrera with about 150kms. I did an oil change at the mechanic shop and few days after i got a CEL. I brought my car back to get the codes scanned and got the following 174-01 Bank 1 camshaft adjustment exceeds limit 322-01 bank 1 timing chain out of position I wanted to post on here and see if anyone has experienced this before. The car drives and runs fine no noises or anyrhing i can hear. Any input would be great. Thanks. |
Nobody ever answered this? My guess is they put the wrong weight oil back in it. If it's too thick it won't pass into the chain tensioner hole when cold which would cause the chain to be loose and the cam timing to be off causing both codes.
Just my thoughts. Tony |
Has the IMS bearing been done? The intermediate shaft turns the cam chains, so if the bearing is failing, the shaft isn’t staying in position. This could be a problem for the engine. Did you collect an oil sample or check the filter. I know I wouldn’t be driving it until I had some answers. Better safe than sorry and lose the engine completely.
