rufrob's Avatar
Suspension noise
Hi all.
I’ve been playing wack-o-mole with suspension noise from my 02-996tt with 36,000km.
Noises occur over small bumps and cracks in the pavement.
First it started with left front. I started cheap and replaced up the price range finally each part having little to no improvement. Finally the LCA solved the noise. Then the right side I changed the right LCA first and the noise was solved.
Now I am getting an thud and rattle from the rear and sometimes sounds like the front. I’ve inspected and can’t find anything loose.
Except for the upper strut mount, every part I replaced looked fine. I’ve tried the pry bar technique on loaded and unloaded components.
Is there another technique for testing suspension components?
I’m thinking swaybar links but haven’t seen much about them going bad.
Any advice would be greatly appreciated.
Never give up
Old 09-08-2019, 05:22 PM
Science is NOT optional
rbogh901's Avatar
my strut mounts made a big difference. that rubber gets old and fails. did you say you haven't done them?
PCA member since 1993
Old 09-09-2019, 10:01 PM
rufrob's Avatar
I changed the front left strut mount. Yes. Big difference. The right side isn’t noisy.
Today I found the left rear sway bar link upper bolt/nut was loose. And left front strut bearing wasn’t seated properly. How did that happen? I tightened it but haven’t had a chance to test drive yet.
Never give up
Old 09-10-2019, 04:10 AM
