Rennline Fire Ext mount - 991.1
Anyone have experience with install of the Rennline fire extinguisher mount for the 991.1?
The instructions say just remove front torx bolts - install the base and reconnect the torx bolts The issue is though there is considerable plastic trim covering the worm gear - other stuff in the way - I'd have to Dremel a good chunk of stuff to make the fitment... thanks kgl
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Administrator
Hi Kim - send a PM to Russ at Rennline and he'll likely be able to give you some tips to simplify the install.
