996 cabriolet, issues using door switch to lower top
I have a 2000- 996 cabriolet. Using the key in the door lock to lower and raise the convertible top was a great feature. turn the key in the cylinder and hold until the top cycles. same for raising.
But now, when I turn the key to unlock the door, the top automatically goes down all the way, without me holding the key in the down position. Very bad when you unlock the car in the rain! Also, now on some occasions, unlocking the door will set off the alarm. These gremlins just started happening all of a sudden. I did have my drainage holes clogged up which did let water into the floor of the car, which has now been dried out and drain holes rectified. Since been dried out and no issues with leaking. Could this still be related, even though it happened a while ago? is this a door switch issue? |
Administrator
Hello and welcome to the forum Craig! Check out the link below to one of our DIY tech articles. I hope that you find it useful - let us know if you have any other questions. Thanks.
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/71-BODY-Convertible_Top_Mechanism/71-BODY-Convertible_Top_Mechanism.htm |
| Tags |
| 996 cabriolet , convertible top , door lock , door switch , lock switch |
