1999 911 Carrera
I have an issue with my 1999 Carrera.. on Page 71 of the Owners Manual talks about Segment Display D, it is about the Engine Oil Level Gauge.. that Oil Gauge Flashes and for as long as it flashes, my car would not start.. that display appears right where the Clock is at.. Oil Level is good, but somehow my car refuses to start, I have to try switching my Ignition Key On/Off several times, sometimes up 8 times, then it finally starts... any ideas? By the way.. the Clutch switch was replaced hoping it would solve the problem to no avail... has anybody experience that problem? Any advise will be greatly appreciated.
Old 12-03-2019, 03:23 PM
1999 911 Carrera
I have an issue with my 911 Carrera.. right where the clock is at on my dashboard, a display appears about the Engine Oil Level Gauge, it flashes and for as long as is flashing, my car would not start, I have to try several times, sometimes up to 8 times, until it starts.. oil level is good, but for whatever reason, it would not start, the Clutch Switch was replaced thinking it would solve the problem to no avail... any ideas? your help is appreciated.
Old 12-03-2019, 03:30 PM
Change the $35 electrical portion on the ignition switch.
Old 12-03-2019, 06:48 PM
Frank, Thank you so much for your reply. I'll do that and for sure, I'll give you an update.
Old 12-04-2019, 09:32 AM
