996 Smoking
Hello fellow car enthusiast !!!!
I apologize if this has already been posted. I appreciate your advice.
I have a 2001 Porsche 996 with 180k miles
I was aggressively driving one day around a curve and out of no where the car just starting smoking really bad the whole cab filled with smoke there was a 200 ft. trail of smoke behind the car.......I parked it came back to get it with the car trailer it started right up no crazy sounds runs fine but started smoking again. Any thoughts or ideas ?
Old 06-10-2020, 06:55 AM
ptrsbtrs
peter leinberge's Avatar
AOS
aka: air oil separator (pray that's it)!
Old 06-10-2020, 07:20 AM
Thats what I was thinking too. Just getting some more advice before I tear it down.
Old 06-10-2020, 07:27 AM
lake wales fla
Start it up and try and take the oil fill cap off, if its really tight dont break the flex pipe. If the AOS is really bad it will have extremly high crankcase vacuam
Old 06-10-2020, 06:04 PM
markp92692's Avatar
vacume checker $ 15
You can make your own vacuum checker w a rubber grommet ( big one ) and a few simple parts from you ACE hardware store
just a little red food coloring and water, your set I think under 4 your AOS is good - somebody provide feedback on the vacuum inches
Old 06-15-2020, 10:27 PM
markp92692's Avatar
engine must be at full temperature for reading
Old 06-15-2020, 10:28 PM
markp92692's Avatar
Old 06-15-2020, 10:34 PM
markp92692's Avatar
engine on at full temp 3in vacuum , take the measurements every year for review
Old 06-15-2020, 10:36 PM
markp92692's Avatar
Sorry last info you tape the ruler on after you set the water level so you have a zero on the water line , heat the engine first, then attach the vacuum to see the pull in inches
Old 06-15-2020, 10:42 PM
The 1st gen M96 3.4 litre engines have the thinnest, weakest cylinder walls making them prone to irregular wear regardless of mileage!
Old 06-16-2020, 11:37 AM
