Jimmy G fuel problem on 996
2004 C4S car was running good had rattle in left resonator, car sat for 2 weeks, did not try to start, changed both resonators, now car will turn over but not start don't hear fuel pump and fuel gauge does not work...what ties the two together ? shorted pump relay did not respond ....will run on starting fluid so not electric problem...could wire be loose inside fuel tank ?
Old 06-25-2020, 07:03 AM
unindicted co-conspirator
looneybin's Avatar
Does the tach needle bounce when you crank it over?
Could be the fuel pump relay
Check the fuses also
Old 06-25-2020, 05:48 PM
tach needle does bounce....will bad pump relay keep fuel gauge from working
Old 06-26-2020, 10:38 AM
looneybin's Avatar
Check the leads going to the sending unit at the tank
Could be a bad ground
You may want to post the question on the rennlist 996 forum also
It has a LOT more traffic and some very knowledgeable people there
Old 06-26-2020, 03:18 PM
