Cooling fans not working 2000 996
Hello,
My 2000 996 C2 Cabrio has been overheating. Trouble shooting led to the cooling fans not turning on as they should (Stage 1 or 2). I have replaced the driver side fan and the thermostat, all relays and 2 fuses. Current Status Stage 1 fans turn on with air con. Neither fan/stage works with engine running (settings 180 deg and 200(?) deg). With Durametric: Key on (engine not running) I can start/stopboth fans and both stages using durametric Engine running I cannot start the fans using durametric. I have a new engine temp sensor. Both the temp in cluster and in durametric are working fine with the original s havent switched it out. Any idea's? all I can think is it could be the ecu(?) I appreciate any help. Thank You! Rick
1980 928 S Euro 1987 928 S4 1986 944 N/A 2001 Boxster S 2000 996 Cabrio |
