For sale! 1999 996 - $19,999 usd
A great example of early model 996 gen 911. Will consider trades or partial trades + cash!
Interior is completely stock and in great shape, no rips or tears in the seats. Black leather with the factory aluminum trim options on the shifter, E-brake, and rockers. Factory Aero Kit, factory lowered suspension, and factory sport brakes. Engine is a 3.4L with 296hp, 6spd manual. Never crashed, never smashed. Upgraded wheels and all-season tires with 80-90% left on treads. Never winter driven. Aftermarket LED tail and headlights. Exhaust bypass with nice rumble.
All original manuals and receipts available for serious buyers.
Several desirable factory options including Limited Slip, Trac. Control, Aero kit, Sports Brakes, Sports Suspension, Sunroof, and more. See all factory codes decoded below. Recently installed new battery, fresh fuel filter, air filter, and new mass airflow sensor.
The 1999 model year also has the stronger, dual row IMS bearing, unlike the 2000 and onward years which only had the single row which is the one that is more known for failing.
Check it out here: https://www.oregonpca.org/ims-saga/
Carfax report available.
The bad: The front bumper has some cracks and needs to be repainted if you want it absolute perfect. Not all of the LED's on the turn signal portion of the driver's side headlight are working. It still signals and still functions to pass inspection but is not cosmetically perfect. If you want to make it perfect you can buy a matching headlight for 400 USD on Ebay to match it.
Factory Option Codes:
030 - Sports Suspension 10mm lower
XAA - Aerokit
X54 - Stainless Steele Exhaust Pipes
X70 - Stainless steel door entry guards with logo
X71 - Alu-look instrument faces
X97 - Aluminium inlay gear lever
X98 - Aluminium inlay handbrake lever
014 - Sports options package incl. 030 375 376, with manual gearbox also 220
139 - Seat heating, left
220 - LSD Limited Slip Differential
222 - Traction control ASR AntriebsSchlupfRegelung
224 - Traction control ABD Automatic Braking Differential
288 - Headlamp washer (disconnected)
340 - Seat heating, right
375 - 2-way electrical sports seat, left
376 - 2-way electrical sports seat, right
424 - CD compartment
425 - Rear window wiper
448 - Sports brake pads
490 - Basic sound system
659 - Board computer
688 - CD-radio Becker Porsche CDR-210 USA
Thanks!
Old 09-20-2020, 05:33 PM
Tags
996 , for sale , sale
