Exhaust Tips
Trying to remove my exhaust tips to polish them up. Removed the 17mm nut and washer, but it appears that the bolt will not budge and go back into the pipe so I can remove the tip.....I have been hitting it with a rubber mallet but it won't budge....any suggestions?
Thanks....Larry |
I had the same issue , first i bought the new clamps and bolts @ pelican once delivered, I went to my muffler shop and had them touched off - the rusted bolt and old clamp,, the heat will the trick you might be able to hacksaw them off, not worth the effort
Thanks I think that is what I will have to do, unfortunately....appreciate the response!
