Fuel smell
92K 2002 996 C4S.....no codes, no problem filling up tank, new gas cap, no visible gas leaks on floor, mileage and performance is normal. The problem is strong gas smell from FRONT of car. Smell persists regardless of fuel tank level. My nose detects smell around fuel level sending unit. No obvious cracks. No apparent broken hoses or disconnected hoses. No smell in rear of car-just front. I do not want to just replace parts. Suggestions?
Ok....for those with similar problem...I removed the “hat” covering the fuel level sender unit, and had my wife start car and gas came out around a crack that originated from one of the lines on the sender. Replaced part and problem solved. If anyone wants to see photos, reply to this thread.
Thanks Eric.
Will stay alert for that.
07 911 Turbo - Pilot Sport Cup 2 ZP 96 Carrera 4 - Toyo R888r 73 911E - Hoosier R7 + twin 75's 92 Corvette - Nitto NT01 14 BMW X3 - Pilot Sport A/S 4 |
Beginning to be a common problem.
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Greetings from Michigan
Just thought I would add another option for folks to check if the below repair doesn’t solve the issue. I had an 06 996 with only 43k miles that had a strong constant gas smell. I pursued the below fix but it ended up being the roll over valve that had to be replaced.
