997.1 Coolant Reservoir Replacement
I have a 2008 4S that has a coolant leak from the reservoir. I am ready to tackle the job this weekend (or next). I have watched several videos (mainly of 996s) and read through the phenomenal write-up on here. I do have one question.
How far can the engine "drop" before it causes other issues? I believe I need to drop it about 2". I also believe that there are just a couple of fuel lines that need to be "popped" out of their respective holders. I have never dropped the engine in a Porsche, so I would be remiss if I didn't say I am fairly nervous about this. Thank you. Ian
1984 911 3.2 Carerra Targa Moss Green - Sold (Big Mistake) 2008 911 Carerra 4S Coupe Macadamia Metallic 1993 Chevy Blazer (Full-Size) 2011 Lexus LX570 - Wife's Ride |
Try this on for size, it is a bit of work, but nothing to be worried about:
https://rennlist.com/forums/attachments/997-forum/1281618d1526760688-the-diy-guide-to-replacing-your-997-coolant-expansion-tank-997-diy-guide-replacing-the-coolant-tank.pdf
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 01-21-2021 at 02:32 PM.. |
Thank you JFP! Great write-up. Any suggestions on how to get it on jackstands? If I used the jacking point on each side, where do I put the jackstands?
I would typically put the stands under the suspension uprights.
Job complete! I actually bought a low-profile motorcycle jack. It worked perfect as it was wide enough to support the engine from tilting as well. No jackstands needed.
Always a good idea to have some jackstands on hand for extra safety precaution
