convertible top not calibrating
I have a 2001 911 that will not calibrate. When calibration is initiated it automaticly stops and the scan tool says end stop not reached. I've test the fuse, checked all micro switches, and done the repair on the front latching mechanism already. Can anyone give me some suggestions on what I should do next.
Did you change the controller?
transducer
Have you checked the top position transducer that is located at the drivers side top actuator? The arm is known to break.
