Vacuum line question
Does anyone know where the vacuum line goes that is coming from the fuel pressure regulator? I had a loose line and I can’t seem to figure out where she goes. There is also another loose line off the right send of the engine.
Old 05-28-2021, 07:43 AM
That plugs into the rubber sleeve that joins the throttle body Tee to the bank 2 intake manifold. If the line on the right side is the same tubing then it is from the SAI and plugs into the sleeve on bank 1.
Old 05-30-2021, 04:24 PM
