Cruise Control Issue
I replaced the four stalk turn signal-wiper-computer control-cruise control assembly on my 2002 996 Carrera. The cruise control worked properly before the replacement but will not engage now. The indicator light for the cruise control turns on when the button is pushed but no engagement. My Durametric program indicates something is not activated but there is no option to activate anything. Does anyone have a solution for this? Thanks, Paul
If your Durametric is the pro model, you can activate the cruise system (below), otherwise you will need access to a Pro model or the PIWIS system to activate it.
