997.1 right turn signal issue
Hello first post here looking for help. I had changed my drl lights to LED and while the left lights are operating fine (replacements have capacitor) the right turn signal throws an error on my dash but two other lights are ok. Besides the error message, the right green arrow lights on the tach is also blinking twice as fast. BUT in checking the actual right turn signal light outside, it flashes orange at normal speed. If you didn’t know about the issues/ error message on the dash you’d think everything is working fine from the outside. What’s happening with the right turn signal that is causing the error on my dash and speeding up the right green arrow indicator? Appreciate any and all input.
Old 11-29-2021, 06:34 PM
Jeff Alton's Avatar
The problem is you replaced your lights with LED. Put the originals back in and your errors will likely go away. Send your LED lights back to EBAY vendor for a refund.
www.turn3autosport.com
Old 12-05-2021, 07:00 PM
AirBorne!
Agreed. Stick with the stock light bulbs. if you want to fancy up your lights the only thing I would do is change the side market lens from oranage to clear. I did that on my 997.1, silver paint, and the diff is huge.
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 12-12-2021, 06:11 AM
Tags
997.1
