Slightly Knowledgeable
996 driver's window not clearing the door gasket
Hi all, fairly new member here, with an '02 996 Carrera coupe. A couple of weeks ago I noticed that the inside door handle suddenly got floppy, which suggested to me that a spring had broken. After removing the door panel, sure enough, the spring that keeps the inside door handle pulled in had failed.
As soon as the spring arrives, I'll install itand that problem should go away. My real question is that I've noticed that my window doesn't clear the door gasket. The window does go down a bit when you open the door from inside. Could this problem be related to the failed inside door handle return spring? The problem existed before the spring actually broke, and I'm thinking that the spring had lost some of its tension, so the switch that lowers the window slightly might not have been fully depressed. Any thoughts? |
There is a microswitch on the handle that tells the window to go down. Its bad or not contacting correctly.
My other ride is a C-130J
In my old Boxster the windows worked fine but the driver door would not “drop” when opening the door. The micro switch was the problem.
I don’t know if a failing micro switch would result in partial retraction of the window.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Thanks for the replies! I think the microswitch is working, as the window will go up and down the fraction of an inch it's supposed to. I'm going to cross my fingers and hope that when I get the new spring in place and the door buttoned up, all will be well.
2009 Porsche 911 C2S, 2002 Porsche C2S (traded) |
The cable that activates the window to go up and down can stretch . While you have the door card off follow the cable visually . If you see play or a space at the end you can take a zip tie and use it as a spacer . You can do a Google search and find out how to do this . Very common on driver's side as it is used the most . Some guys use bicycle adjustable cable ends like that used on bike brakes . Yours is obviously working as it is dropping some just not enough . Classic cable stretch .
Just to wind things up, the new spring that holds the inside door handle closed is installed, and the door is back together. That seems to have fixed the problem with the window not clearing the door gasket.
Thanks to all who replied...
Congrats! Any photos of the repair?
Sorry, no, I didn't take any pictures. It seemed simple enough that I didn't feel the need to document it.
BTW, I like your "other ride." Very cool to drive one of those big cargo planes!
