Break lights not working at all
Hello,
Break lights not working at all. Checked the fuse, and it is good. Any other ideas? All three lights are out. |
Porsche 911 Carrera S
The brake actuation switch? When at cruise controlled speed, does the throttle disengage when the brake pedal is pressed?
________________________________ John - 2005 C2S 997.1 at ~82k mi |
Administrator
I would investigate the brake light switch. On most vehicles it is mounted up near the brake pedal itself. Usually towards the top part where the pedal pivots. It's usually pretty easy to access under the dash after you pull an interior panel or two out.
-Matt |
