No brake lights
I have a 2002 996 cab. Just recently all three brakes lights stopped working. The fuse is good, the bulbs are good and I’ve replaced the brake light switch. Any other ideas on where to look?
Porsche 911 Carrera S
Check for voltage at those three spots you mentioned - brake light switch, fuse, bulb holder and then develop a theory based on those findings.
Ok, had power to switch and the replacement switch was an OEM apart from a P dealer. Wife noticed lights would come on for a second then go out. First thought was a loose connection somewhere but happened repeatedly when just exercising the switch. So thought was a bad switch again. Installed another switch and the lights are working fine! Much better than trying to find a wiring issue.
