996 With Coolant Issues
I need some help diagnosing a 996 issue:
This car is a 1999 996, ~80,000 miles. No work ever done on the engine AFAIK, car has a slight tune done by previous owner. In general the car drives and pulls like any 996, maybe better, this is not a weak clapped out engine. Zero issues driving the car 'sedately', but if I drive it hard: - Overtemp light goes on, coolant temp goes to just under boiling - Coolant system seems over-pressurized, never seems to blow off - Car runs fine with zero other issues when the two points above happen - If I let the pressure of the system the coolant returns to normal level - I am not losing coolant - If I drive the car and let it sit a week, the coolant system is still pressurized - Coolant might have a slight exhaust smell, or I'm paranoid... I am thinking small crack in the cylinder? Head gasket? Could my rad cap be the problem? If it doesn't relieve properly that might be the issue? Probably not a good outcome here...
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Time for diagnostics instead of wishful thinking: There are tests kits to check for the presence of exhaust gases in the cooling system; the test is a go/no go test, if the engine fails the test, you have a problem.
Sounds like you have an air pocket in the cooling system.
Dan 2001 Boxster S (for sale soon) 2024 Tacoma TRD Offroad 4x4 2027 KIA Telluride SX |
