Water Pump
I have a 2003 996 Targa with about 36,500 miles on the car. When is it recommended to change the water pump on my car?
Old 06-07-2022, 03:05 AM
2001 Boxter S
At 60k miles is a good time.
Old 06-07-2022, 09:57 PM
If you have the original water pump in your car, it very likely has a composite impeller and these impellers have a reputation for disintegrating. Since the composite ages with both use and time, and its almost 20 years, I would replace the water pump and thermostat ASAP. There is some disagreement about the use of a water pump with a metal impeller as an improvement, and Pelican staff say it is fine to use either. I replaced mine at 54K miles/20 years with the composite only to find the previous owner had already replaced it with a metal impeller. So now the car is on its third pump. At least I sleep well at night.
Old 06-14-2022, 02:51 PM
Check the link below. I’d take an expert view over a parts retailer. They can wear away at the engine side and wreck the engine.
https://forums.pelicanparts.com/boxster-cayman-forum/992269-any-thoughts-metal-impeller-water-pump.html
Tony G
10 Porsches come & gone!
1962 Morgan Plus 4
Old 06-24-2022, 04:14 AM
