Air bag light on
Code reader says the fault is ignition circuit side air bag driver unable to evaluate.
Can anyone tell what could cause this please?
Old 07-15-2022, 09:51 AM
Oh, it’s an 02 C4S. I was asking questions about this yesterday under a separate posts. Brought it to a mechanic who read the code above. Thx
Old 07-15-2022, 10:10 AM
Did he or she give you the specific DTC code number? Without that, it is pretty much guess work....
Old 07-15-2022, 10:25 AM
Would I’d be something like 13-00?
Old 07-15-2022, 10:45 AM
No, DTC codes are usually P plus four digits, like P0301
Old 07-15-2022, 12:48 PM
The code was taken using a Snap on P1000 and there was no letter designation. Only 13-00 followed by the description I provided above.
Old 07-15-2022, 01:44 PM
Is this car a cabriolet?
Old 07-15-2022, 01:55 PM
OK, after some research into Snap-On diagnostic systems, and some translation of one fault code system into another, it would appear you may have a driver's side seat belt buckle issue. Porsche developed a fix for this which consists of a new buckle and its wiring harness, which seems to be a permanent fix. Parts are about $100 or so, and then the code can be cleared.
Old 07-15-2022, 02:43 PM
My other ride is a C-130J
RNajarian's Avatar
Good info JFP.
Would there be a TSB on that ?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 07-15-2022, 04:17 PM
Thanks ever so much for taking the time to cross ref the codes and help. Do you think once installed the snap
On tool can clear the code or maybe even my Schwann? The closest Porsche dealer is well over an hour away and I have yet to find anyone near me with PIWIS. Any chance you have a part number? Again many thanks
Old 07-15-2022, 04:40 PM
RNajarian's Avatar
I invested in a Durametric in 2008, just recently upgraded to their Pro version. This tool clears Airbag Codes and does programming on certain Porsche models
Old 07-15-2022, 04:47 PM
I’ve owned this car 7 years. I’ve taken a deposit on it and this light just came on for the first time ever. It may be a deal breaker but I don’t want to buy a durametric.
Old 07-15-2022, 05:10 PM
Good info JFP.
I believe there was.
Old 07-16-2022, 07:59 AM
It might even clear itself once the repair is completed, but the Snap On tool will definitely clear it if necessary.
Last part number I have is 996-803-183-09, but as they have superseded this particular part a couple of times, I would check with a dealer parts department first.
And as replacing this unit is within the airbag system safety protocols, you need to read up on how to deactivate the system so you can work on it without getting a face full of air bag.
Old 07-16-2022, 08:00 AM
Well this is my 2cnd 911 . Owned the two combined for almost 20 years. Had both engines out and did the ims on the C4s and never once went to a dealer. Until now that is! Lol. Made an appointment for Wednesday as I have a deposit on the car and the light would stop the deal! Having PPI there too which although the car runs excellent concerns me they will be super nit picky. Thanks for your help but the more I read the iffy I felt about being able to resolve this myself. An airbag deploying would have freaked me out to say the least.
Old 07-16-2022, 11:41 AM
clear seatbelt code
I went through this same episode a few years ago, and ordered the repair kit. The repair involved replacing pins in the belt connector, but the old pins would not budge (I guess you need a special tool for this). Instead, I bought a new buckle with connector-easy install, and cleared the code with a Durametric
Old 07-17-2022, 02:56 AM
Well I found a red wire with blue or purple stripe on it within the harness in the running board after of the trunk that had been chewed off. I was able to solder it��. The light is still on and my schwaben can’t clear it. I thought perhaps that wire wasn’t the problem but I took a look under the seat and seems there a red w purple stripe wire going to connector junction. So maybe all I need to do is have someone w the right tool clear it?!
Old 07-17-2022, 10:40 AM
Seriously doubt it.
Old 07-18-2022, 08:01 AM
Well I broke down and drove an hour to Porsche today. It wasn’t the wire I suspected as they said they can’t even shut off or clear the code. Although I had an appointment to diagnose or fix it they sent me home. Told me they had to get pricing and would email estimate. I get home and they had pricing for a bunch of other stuff and want more $ to open the door and investigate more! What BS after I spent 1/2 a day and hundreds.
Old 08-11-2022, 01:58 PM
It was the airbag control module and with a used one installed I cleared the codes and light with a Schwaben.
Old 08-23-2022, 09:03 AM
