passenger window stuck up
help my passenger window is stuck in the up position and will not move with the window switch. when i use the switch i can here a click both up and down (micro switch?) when pushing the window button but no movement at all.
tried disconnecting the battery and reconnecting, nothing at all. tried pushing down on the window while using the window switch nothing. does not drop at all when door is open. does not move when the door is shut. drivers window works fine. tried to raise and lower with the door key only the drivers side works. update: the passenger window regulator looks good. removed the motor from the door but the motor only runs in the up position but will not work in the down position and i can here the switch for the down position activate when you use the window button. so i am thinking motor unless the door latch micro switch would affect this. please chime in with your past experiences before parts are ordered. |
Sounds like you found your culprit, but you could swap the driver side motor either fully if it is a direct match, or just electrically to test.
Your article content is being very much interested, I am very impressed with your post. I hope to receive more great posts.
Tell Happy Star Last edited by WashingtonAQ; 10-18-2022 at 08:15 PM.. |
