997 - wet on the inside!
Now that the weather has turned colder my 997 is wet on the inside. In fact I have had nearly as much ice on the back window on the inside as the outside! The front window is damp as well. This is highly annoying .... any ideas ... door seals maybe?
Old 12-30-2022, 06:07 AM
rfuerst911sc's Avatar
Is the car parked inside or out ? Is it a cab or coupe ? Run your hands across ALL carpets to see if they are wet .
Old 12-30-2022, 09:59 AM
jluetjen's Avatar
The 986 Boxster that I have has 7 different drains -- 3in the front in the tray under the battery, and 2 on either side in the back (2 in the rain gutter either side of the cover for the roof, and 2 in the foam tray under the hinges. I suspect that the 996/997 are similar -- especially in the front. Make sure that they are all clean and not clogged with leaves, pine needles and such. The best way to clean them out is with a vacuum. Pushing debris down the drains is not advised -- far better to vacuum the debris up.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Last edited by jluetjen; 01-02-2023 at 04:41 PM.. Reason: Oops! I forgot that I was posting in the 996/997 forum and not the 986/987 forum!
Old 01-02-2023, 04:38 PM
