proporsche's Avatar
Porsche 996 2005 brake and back up lights stay on
Hi boys. I am trying to help a friend with his car.Hi battery was dead after jumping through the fuse box to get to the battery to open the hood ,which is now replaced, the brake and back up lights stay on.Anybody has a idea why and what to do?
Thanks for any help.
Ivan
1985 911 with original 503 432 miles...810 195 km
Old 01-12-2023, 04:57 AM
proporsche's Avatar
Nobody?
Old 01-16-2023, 06:05 AM
Oh, we are reading this, but have no good ideas, really. Since you had to take the cover off the fuse
box, I would check to make sure everything is in the right place. Can you verify it is the brake light that is on and not the driving light? Until you get an answer, your friend should pull the fuse for each of those things so that they don't drain the battery.
Old 01-17-2023, 11:33 AM
proporsche's Avatar
Thanx,the car will be arriving on Friday,yes my plan is to isolate
One fuse at a time.The boy on the other end said
The back up and tail lights stay on.I will set on Friday
Ivan
Old 01-17-2023, 01:30 PM
proporsche's Avatar
The has arrived Florida.from CA..,if you would shutoff the car and lock the car, back up and brake lights stay on.
So I disconnect the fuse 6and 7 drove it a little but now even if I put the fuses back no brake lights.Got an appointment on Monday for diagnostics....will know. Later
Ivan
Old 01-21-2023, 05:42 AM
Thanks for the update.
Old 01-21-2023, 08:22 AM
proporsche's Avatar
Well,now by I am playing more with,found out that fuse no 4 in !ineC is just for brake lights.will put back in 6,7 and see...?
Also it could just a coincidence and the pedal switch is bad..
To be continued on Monday
Ivan
Old 01-21-2023, 11:44 AM
proporsche's Avatar
Looks like my theory worked.I left all 3fuses out over night and today I have at least the 3rd light working.Could be that the complicated el. System is reset by itself?
Ivan
Old 01-22-2023, 08:02 AM
proporsche's Avatar
Update..went to a dealer today,problem was the big rains in LA recently.The floor was full of water,drains were plugged up.The module under the driver's seat was kaput with that water there and the car sitting like that for 2month..all works now..
Ivan
Old 01-23-2023, 02:43 PM
Oh, that makes total sense. Thanks for sharing. I'm beginning to think anything that seems illogical is the module under the seat.
Old 01-23-2023, 03:03 PM
