WTB: factory a/c hose clamps
I need another 8 of these clamps.
Anyone who has removed the a/c from an early 911 may have them...? (it's always the stuff we throw away that we need later) Metal band was yellow zinc.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I think I may have these but I could have thrown them out. I’ll check and get back to you!
Did you check with Porsche? I see 999-511-066-02, which looks like your picture, in the parts catalogue. $3.40 from my local dealer. You could probably get it through our host, too.
Thank you, Tom!
I didn't have the number and I see they can be bought new, which suits the car I'm using them on.
No dice sorry! They got thrown out with the crusty old hoses.
Good luck in the hunt! |
So, still on the hunt for original type clamps. Closed ID about 25mm
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher Last edited by techweenie; 04-26-2023 at 05:55 AM.. |
Senior Member
There are marine grade clamps with stainless that would work perfect, just not the yellow zinc. Belmetrics has a variety of same for a couple of bucks each.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
Thanks!
I can get them finished in yellow zinc… Found them on McMaster as well.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher Last edited by techweenie; 04-26-2023 at 06:23 AM.. |
Senior Member
Spruce Aviation has some yellow zinc options as well, but would recommend calling to make sure of the finish.
Of all places, I found them on Amazon. Ten bucks a dozen!
link? I also will need new ones for my build
Thanks |
Can’t link because its in the Amazon app. But this is the info.
perfect thank you
Looks like you found what you need but you’re welcome to all the AC hardware I pulled off my 81 if it helps
1978 911SC |
Thank you!
