Used 2.2 911T Pistons and Cylinders, Set of 6
I recently bought a used set of Porsche 2.2 911T pistons and cylinders, but I now will not be needing them. It turns out my engine just needed the head nuts retorqued. Here is your chance to get that replacement piston or pistons you need for your rebuild. All the fins are intact, and the piston domes have only a couple of small notches where they touched the exhaust valves at some point. One cylinder has some rust at the lower side of the bore, but it seemed to pretty much clean up with just a few passes with a ball hone. I used a Feeler gauge to check piston to cylinder clearance and they all seem to be in spec.
I don't want to break up the set of 6, so I have priced these low enough you can buy the whole set even if you just need one or two. Send me a message if you want more detailed photos of any particular area. I accept returns if you don't like them, so there is not a lot of downside risk here. I am asking what I paid for them, which is $350 for the set. If you think that is too much, make me an offer. I am a reasonable guy. ![]() ![]()
Are these still available?
Banned
pm me on (901)*593-2249
