Porsche special tools lot
Greetings everyone, I have a lot of Porsche special tools available which came from the estate of a master Porsche tech. I've gathered as much info on them as I could find and have listed it below... It is a bit hard to follow as I copied it from Excel so formatting got blown away but expanding the screen helps.
*EDIT* Looks like I'm parting this lot out~. Anyone who reached out has been contacted and has first dibs. Trying to locate pricing on these parts is just about impossible so I am going to set prices at random and ask for offers... prices to be added/updated shortly. Thanks! John Tool Number My Notes Listed description Book Description Book info Porsche Part # SOLD $250 - P37 Locking plate for drive shaft 911, 912, 924, 914, 914/6 000.721.037.00 $150 - P55 Pressing bevel Pinion shaft & Driveshaft/Intermediate plate To press intermediate plate onto main and pinion shafts 356 SOLD - P65A - Z14 To remove inner roller bearing race from main shaft 356 SOLD - P65A - Z11 X2 For removing the roller bearings inner ring from the drive shaft 356 SOLD - P82 For installing and removing the rear axle seal 356C $80 - P103+? Similar no # also Oil seal installing tool Carrera? For installing oil seals at main bearing #1 000.721.103.00 $50 - P216 Installing seal ring of bearing #8 belt pulley Installation arbor Installing seal ring of bearing #8 belt pulley - 911, 914/6 000.721.216.00 SOLD - $50 - P218 Flywheel bushing Arbor For installing and removing the flywheel bushing - 911, 914/6 000.721.218.00 SOLD - P220 Measures thrust play of intermediate shaft Dial gauge holder For measuring thrust play of intermediate shaft 000.721.220.00 SOLD - $100 - P260 Used for holding 901 & 914 (NOT 915) gear shafts and selector rods when adjusting shift forks. NA 000.721.260.00 SOLD - $40 - P263 Removing rear diff bearings Press accessory For removing the bearings at the differential housing 928, Rear wheel suspension, transmission 924 Turbo: Wheel suspension - 911, 912, 924, 928, 944, 914, 914/6 000.721.263.00 SOLD - P294 Thrust member For installing the oil seal on the rear brake backplate - 911, 912 000.721.294.00 SOLD - P298 Installing roller bearings in rear suspension arms Thrust member For installing and removing the roller bearings in the rear suspension arms - 911, 912 000.721.298.00 SOLD - P356B Fitting tool For swivel flange tightening taper bolt - 911, 912 000.721.356.20 SOLD - $60 - P359 Pressing SM silicon seal in torque converter Installer For pressing the small silicon seal in the torque converter - 911, 912, 914, 914/6 000.721.359.00 SOLD - $40 - P362 Mandrin For installing the seal in turbine torus 000.721.362.00 SOLD -$40 - P370 Centering mandrel For clutch drive plate - 911 - 1972 000.721.370.00 SOLD -$40 - P373 Centering mandrel For clutch drive plate - Sportomatic 911 - 1972 000.721.373.00 SOLD - $40 - P375 Press-out mandrel For pressing out the bushes at the clutch lever shaft for clutch actuation. 924: To drive bearing bushing into clutch release lever - 911 - 1972, 924 000.721.375.00 $80 - P401&P402 $60 - 21/2 - 21/10 Missing 21/8 SOLD - $30 - 2056 Pinion shaft installer $80 - 2069 68479 $40 - 2519 Hazet $100 - 3042 Matra 91779 $40 - 3176 $40 - 6875 Fan Tool $40 - 9102 Centering spindle For centering the driving disk, 924: 924 turbo only. 924, 930 000.721.910.20 $60 - 9119 Driver For sealing ring of the input shaft - 924 000.721.911.90 $150 - 9142 Holder For loosening the nut SW55 on ring pinion and assembly with torque in conjunction with 9143 - 928 000.721.914.20 $60 - 9148 Remover For pressing out drive pinion from case and to pull off drive shaft in conjunction with 9140 - 928 000.721.914.80 $50/each - X2 X2 “Lock bars” Wrench For installation and removing of balance shaft drive gears - 944 000.721.920.00 $80 - 9234 Camshaft seal installer 77-95 Camshaft seal installer NA 000.721.923.40 SOLD$250 - 9253 930 G50 Transmission lock tool NA SOLD - $80 - 9500/3 Piston installing tool SOLD - $80 - VW191 Matra Crankshaft seal Insertion tool for crankshaft oil seal (flywheel side) 914 $60 - VW202u X2 x2 puller Fan puller NA SOLD $75 - VW381/5 Peiseler Backlash tool $40 - VW383/5 Ring gear drive pinion tool $40 - VW384/2 $200 - VW390/1 Peiseler $40 - VW390/3 Matra Type 4 Gearbox $120 - VW458 Thrust plate bearing puller $40 - VW761 Matra SOLD - VW203b - ? SOLD $250 - P37A - Specific to 72 911? $80 - P223 - Syncro hub removal tool? SOLD - $80 - 9104 - 930 holding fixture for drive shaft SOLD - $160 - 9106 - 930 holding plate for locking shift rails
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! Last edited by JJK78-951; 09-16-2023 at 08:58 AM.. |
I’d be interested in P37 lock tool if you decide to part.
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
If you decide to part the lot, I'll be interested in P65A/82/220/294/298 and VW203
Thanks! John
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! |
Did these come from the gentleman in Jacksonville?
gearhead
That’s a steal for $2k.
1974 914 Bumble Bee 2009 Outback XT 5MT Ltd 1970 914-6 GT conversion racecar |
No he was north of Atlanta, GA~
Thanks Matt! Hopefully someone out there could use this lot! John
EDIT: I'll start separating bits as requested.
Thanks! John
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! Last edited by JJK78-951; 05-09-2023 at 08:28 AM.. |
I would be a buyer for the 2 input shaft holding tools
Does anyone know if this sold as a lot?
Hi Rick,
Lot has not sold yet. I did just see your email in my junk folder this morning... I believe a few of the pieces you requested have been asked about already but will need to look through the messages to see who is in line for what~ Not really looking forward to trying to figure out pricing on this stuff individually but looking like no-one wants the whole lot so I'll start getting together a price list, give me a few days~ Thanks! John
Thanks John, I am sending you a PM
SOLD $250 - P37A - Specific to 72 911? $100 - P223 - Not the Syncro hub removal tool, but some older version of the P223? SOLD $100 - 9104 - 930 holding fixture for drive shaft SOLD $250 - 9106 - 930 holding plate for locking shift rails Trying to find any pricing on most of these tools has been very difficult so I'm just guessing really! Feel free to make an offer on them I won't be offended. I'll be adding prices to the main post later today. Thanks!! John
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! Last edited by JJK78-951; 06-08-2023 at 04:47 AM.. |
Several tools found happy new homes today, thank you all!
Prices now listed in main post for individual tools, mostly just prices them based on size so feel free to make an offer! ![]() THANKS! John
Lowered prices!
Thanks! J
Happy Monday everyone~
TTT Thanks! J
More tools sold but plenty still left! Or feel free to make on offer on the lot!
Thanks~ J
Got special tools?
BUMP! Thanks J
Bump.
Will sell remainder of the lot for $750 Shipped in the US. Thanks J
Hump day. Bump day.
Thanks! J
