Porsche 935's Avatar
WTB Used TDC reference sensor
Only need it for male plug , so doesn't matter if sensor is bad as long as plug is good.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 04-29-2023, 09:50 AM
Bump
Old 04-30-2023, 04:28 AM
touringmandan's Avatar
If it's a Bosch crank reference sensor, do yourself a favor and buy a new one. The standard mode of failure is the male plug "housing" plastic failing and crumbling to bits. The plastic seem to hold up for 12 years or so. Don't touch it after that!!
Hope this helps.
Old 04-30-2023, 06:58 AM
Since only the plug broke into pieces, I have located a new plug end. Hopefully inserting 3 pins into a connector will be easier than replacing the whole unit. Will let everyone know when it arrives in a couple days.
Old 04-30-2023, 12:19 PM
