Car won’t start - 07 997 (Crank No Start)
Good morning everyone, I apologize in advance for my bad English
I own a 2007 Porsche 997 turbo in Italy. Yesterday it worked perfectly, today it doesn't turn on anymore! Car won't start (Crank No Start)
when I try to start it there is a strong smell of petrol do you have any advice for me? Thank you |
Sounds like no spark. Check for spark, maybe Flywheel position sensor quit? All fuses good?
2002 996 C4S
Not sure if it is the same on the 997, but I replaced my Battery Cable to the starter and all of my starting issues went away.
The cable was totally corroded (which I could only tell AFTER I took it out). I also replaced the starter but 99% sure it was the cable. Post where I worked through the issue: https://forums.pelicanparts.com/porsche-996-997-991-forum/747417-1999-996-wont-start-when-hot-cranks-2.html#post11657671 Part I replaced: https://www.pelicanparts.com/More_Info/99660701901.htm?pn=996-607-019-01-M100&bc=c&q=starter%20wire
jcsjcs Have: '02 996 C4S Had: '87 944, '84 911 Carrera Targa |
