Clutch hydraulic fluid
Ok need some help here. I have searched online and cannot find a clear answer I even check the owners manual. Does the clutch hydraulic system take break fluid or the CHF 11s 99 996 cab? I dropped the motor and replaced the slave cylinder so I need to flush the system just not sure what fluid to use.
1982 911sc 1999 996 Cab Last edited by Bman49erfan; 08-17-2024 at 07:35 PM.. Reason: Forgot to add year and make |
Brake fluid. Use a good high temp fluid like Motul 600 or 660.
Thanks Tony I knew someone would know the answer
1982 911sc 1999 996 Cab |
