Engine bay round connectors
Question of the day… So, I just finished putting the motor back in and fired it up. Its running at a very high idle 3500 rpm. Is it possible that I switched the two connectors in the engine bay. One has two white dots and the other has two blue and it the one place I didn’t take pre photos of. Right now I have the two white dots on the bottom connector.
Just not sure if they are interchangeable as it looks like the triangle alignment in the center is the same on both connectors.
Yes, I will be checking for vacuum leaks and unplugging the MAF to see if that changes anything. I tried turning on the ignition for one minute to reset the throttle body but didn’t hear anything reset in the engine bay.
1982 911sc
1999 996 Cab
Old 08-26-2024, 06:22 AM
