996 won't start
Symptoms:
Car (996 C4 tiptronic) won't start, However when connecting a simple OBD reader it starts.
Keys can lock and unlock the car, dashboard light etc works fine even without OBD connected. Fuses under steering wheel ok. Brake switch ok.
Anyone that have had the same issue or have some ideas where to start troubleshooting?
Thx
Old 09-09-2024, 12:02 PM
Thats quite bizzarro. My initial thought was an immobilizer, but that still doesnt make sense.
What symptoms did you have before this?
Simon
Too many projects & a daily TDI:
-1966 Lotus Elan FHC (wasnt supposed to be a project)
-1969 Porsche 912-6 (not a project, yet)
-1986 325es with a 10:1 2.7L M20 (trying hard not to be a project)
Old 09-17-2024, 06:56 AM
Maybe this is obvious but did you try with gear lever in neutral? Park switch may be worn?
Old 09-20-2024, 11:49 AM
rfuerst911sc's Avatar
Has the ignition switch ever been replaced ?
Old 09-21-2024, 02:02 PM
Have you tried checking the park/neutral switch? It could be something simple like that. I've seen similar issues before where shifting to neutral got things working again.
1976 911S Targa
Old 09-21-2024, 11:52 PM
Hi,
Ignition switch changed no difference,.
No difference if gearbox is neutral or park.
Assume OBD reader grounds something??
Thx
Old 10-09-2024, 01:39 PM
