Temperature Gauge and needle "Red blinking"
Hi 🙂
I have a c4s from 2003. To resume my last change on my car last month : Water pump Calorstat Coolant Expansion vase with the level sensor Belt and belt bearing Drive at least 300km with no problem. I had a trouble with the steering pump but it was just a bad connection and lost liquid and need to clean all behind the pump. After that... After some kilometers I had the red warning light (blinking) and the needle go down (Motor Temperature). Sometimes it stop and sometimes the problem coming again. I saw that the day after looking for the steering pump, It was strange. The needle Temperature go up very slowly but no red warning. If I let the car in the garage and wait, the needle go to the normal Temp. Slowly. I change the Temp sensor on the Oil pump. Same problem. I put the old level coolant sensor. Same problem. The weather is a little bit cold but last year no problem. I have my Oil pressure who seems to be at the end of is live (saw it from a long time) and when the warning come for the Motor Temp the needle of the Oil pressure seems to be "normal". I lost my mind with this problem 😕 Anyone can help me ? Thank you 🙂 |
Four functions of the coolant warning light:
1. Engine coolant level too low — light flashes slowly (0.5 Hz) 2. Engine compartment temperature too high — light flashes slowly (0.5 Hz) (engine compartment blower might be faulty) 3. Engine coolant temperature too high — light is lit; pointer on the right 4. Temperature sensor at water outlet faulty — light flashes rapidly (1 Hz); pointer on the right Note The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously (1Hz = 1 flash per second. 0.5Hz = 2 seconds per flash) __________________
![]() I'm in the case 4 but already change the T sensor :/ I can't upload video :/ |
