Crotchety Old Bastard
LED Brake Light throws ABS/PSM code. Fix?
Installed aftermarket LED tail lights in my 2001 996 and the resistance is throwing ABS/PSM codes. I've heard of flasher issues when installing LED bulbs (don't have that problem) but not brake light related codes. Does anyone sell a plug and play resistor harness to cure this problem?
Thanks!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
The fault you are seeing is likely caused by the pedal switch getting connectivity before brake pressure, or not enough resistance. Its normally a problem with the pedal switch, have not seen it with an LED, but then we don't seem many 996 cars with aftermarket taillights.
Hey Jeff, I believe the codes are being thrown due to the LED brake light bulb having a weak resistance compared to OE bulbs. The computer thinks the brakes are on or the bulb is burned out. There are 3 wires on the brake light harness, red brown and black. Which colors would I jump with a resister? Looked at wiring schematics and can't make it out.
Problem solved.
Did a little research and found this is a very common problem with a very easy solution. Purchased a set of 6ohm 50W resistors in a plug-in kit. Spliced into the black and brown wires. Done. Idiot lights immediately went out. Also note that the cruise control is affected by this voltage issue as well; it thinks your brakes are on so it will not engage. All works as it should now. Hope this helps someone.
