Bypass valve clearance
Ok, I posted this in the 924/944/968 forum, thinking more people would see it there, but still got no response. So I'll post it here and hope that somebody who knows the answer will see it here:
Does anyone know how much clearance there is between the bypass valve and the hood? I'm pretty sure mine has failed, and I would like to replace it with the valve in the link below. It was designed as a direct replacement for the 25mm Bosch valve, but it's a bit taller than the Bosch valve, so I'm not sure it will fit.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TXS%2DRBV%2D25&N= 400350+311294&autoview=sku
Old 09-24-2005, 06:57 PM
Super Moderator
nize's Avatar
is there any reason why you want the summit one?
i know for a fact that this one fits and works properly for the 951;
http://www.*****************.com/product_p/ebdv18-b.htm
or if you want the polished look;
http://www.*****************.com/product_p/ebdv18-s.htm
Old 09-28-2005, 12:19 PM
Get an updated stock one: http://www.*****************.com/product_p/pp993.110.337.50.htm
Unless you really feel the need for more bling. It'll probably last the rest of the life of your car.
-Ian
Stock 1988 951, TT aero wipers
Old 09-28-2005, 12:36 PM
Mahler9th's Avatar
Ditto what Ian says... there is a lot of hoopla about cbvs.... the stock ones are just fine. I'd use the money for something else... (and I did....)
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 10-12-2005, 01:14 AM
Cars & Coffee Killer
legion's Avatar
That one looks a little tall to me. I got the billet piston-type BOV from Lindsey Racing.
5 liters of VVT fury now
-Chris
Old 10-12-2005, 06:45 AM
ae1969's Avatar
I installed an HKS SSQV.
If you want to talk no room.........that thing leaves you no room.
Any of the bypass valves mentioned will work well. The original valve was slightly under engineered. A rubber diaphram will tear it is not if but when...... The updated 993 by pass valve will work just fine if cost is an issue.
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-12-2005, 06:51 AM
