falter or hesitation from idle
86 951, engine falters from idle, once I am up to speed and not accelerating the engine runs fine. If I step on accelerater the engine hesitates again. Any ideas?
Old 11-12-2005, 03:44 PM
Ornery Bastard
Vacuum leak under boost? That's happened to me a couple of times. A hose clamp will fail and then whenever you get into boost it'll all vent off and screw up the fuel metering.
Old 11-12-2005, 10:46 PM
Aaron,
Thanks, this problem is not related to boost, it starts faltering when I raise the rpm from idle. If I add rpm very slowly I can get the car up to speed. If I step on the gas once I'm at 30-40mph the car stutters everytime
Old 11-14-2005, 02:17 PM
Ornery Bastard
I still think that something vacuum related is likely.
Old 11-14-2005, 05:58 PM
I agree with Aaron, it sounds like some sort of a vacum leak. I would also look at your intake, mine did it when there was a leak around the BOV.....simple hose clamp fixed mine.
Old 11-14-2005, 06:07 PM
Thanks guys,
I wil check this out let you know the reults
tom
Old 11-16-2005, 03:25 PM
