Vlave Stem Seal Replacment
I've been noticing a bit of smoke out the tailpipe for a while now. It use to clear itself within about a 1/4 mile. Now it takes a bit longer and mildly noticeable at idle. Car has got 88k on it and I am the original owner. I've used M1 15/50 synthetic since about the 3rd oil change (about 10k miles). I suspect it probably needs valve stem seals. Before I dig into this, I was wondering if there are any sites out there or forum members with hints and/or instructions on replacing valve stem seals. Any help would be most appreciative. Thanks a bunch.
86 951 blk
Old 11-20-2005, 03:50 AM
rudidelange's Avatar
Maybe its not the valve stem seals, they still should be ok with 88k and synthetic oil.
One of my injectors leaked - and it blew some smoke on startup and when accelerating - replaced injector smoke gone.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 11-29-2005, 05:39 AM
I would think that a leaky injector would make the car idle erratically in addition to the smoke. I'll look into it anyway.
86 951 blk
Old 11-30-2005, 02:33 PM
What color is the smoke? White is coolant, blue is oil, black is unburned fuel/carbon build up.
Check the spark plugs. The insulators should be a dark yellow to orange color. Bright Orange/Yellow to white indicates a lean fuel/air mixture, while brown to black indicates rich mixture and/or oil burning.
While you're at it, check the intercooler hard pipes. Turbos like to leak oil.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 01-11-2006, 12:23 PM
