What is the best Roll Cage?
I'm looking at a 944 S2 which I will be using exclusively for DEs. I want to install the BEST roll cage. The car will have driver and passenger seat. Am I correct in believing that a full welded in cage is best?
Recommendations for brand, name - and possible installer in the NY metro area? Thanx. David |
The best roll cage is one that never has to be used!
If you want a pre-bent one. The Autopower is nice. I have the "U-Weld" cage with the racing roll bar. You should be able to have someone put this in for you at a nominal fee. I welded mine in my self and it was very time consuming. The cutting and fish-mouthing took alot of time.
If you plan on racing, check the Rules of the sanctioning body on the types of cages you can use. Some allow for smaller tube than others and some require different cages based on the class you run in.
Geoff Baltz - St. Louis Region PCA Board Member/DE Chairman PCA HPDE Instructor |
If your interested I'm currently producing custom built cages, pieces pre-bent and coped ready to weld to your mounting plates.
Price will be very competitive for what your getting. Whatever you do put a lot of thought into what your going to do with the car, cause it's pretty much a one shot deal. Weld in will be best if properly designed. |
Super Moderator
I have lots of other photos but no web site yet. Will make it to your spec's, currently have one ready to ship, pre-coped and trial fitted made from DOM 1.75" .120 wall tubing. The intent is to match SCCA IT spec's. Come's with NASCAR style door bars. Mounting plates are your responsibility. If your interested e-mail me at [email protected], base price is $750 plus shipping approx. $100-120 anywhere in the US. |
Beaver Racing?
Non Compos Mentis
Glen!
Welcome to the board! Glen and I used to dice it up together on the autocross track, and have spent a few days chasing each other around in circles at Pacific Raceways with the PCA. He's a great guy. I'm now autocrossing in a different class (for some reason when you swap in bigger engines they don't let you stay in the stock class) and road race my little 944NA. My cage was custom welded by a local guy who had done several SCCA 944s prior to mine. If I needed a cage today, I'd have no problem trusting Glen's workmanship. |
